I have a Johnson 6hp 6r-72d. I have installed new water pump, plugs, wires, carb kit and thermostat. The engine has 90 and 85 psi compression. The points and coils look brand new and I double checked the adjustment on the points. The spark has a good snap and is nice and bright whitish blue. As far as fuel goes. I am getting fuel to the carb (because I can smell it and if I over pump the bouble it come out the intake sometimes). I am not sure what the adjustment should be for the needle that is adjustable but I have tried to start it from 3/4 backed off to one full turn backed off. Neither way does it help beter than the other. I have pulled and pulled on this thing and it would not go. I even used a drill to turn it over because my arm got sore. Oh ya I was standing on the primmer bouble one time while using the drill and it still did not start so I do not think it would be the fuel pump.
Maybe someone crossed the plug wires so if someone has that direction I will check that quick.
The other thing is the carb needle adjustment? Turns?
Any other sugrestions would really help.
Thank You,
Greg
Thank You,
Greg
