6hp Viking ob
Eaglesfan85
Hi I just bought a Viking motor 6hp. Model# 64501 just wondering if anyone has any info on this model? Gas/oil ratio etc. thank you
SeaKaye12
Re: 6hp Viking ob
Yeah; I see what you mean. It seems to skip over it. I guess you might have already seen this link?
Anybody know about eatonbs Viking motor
And this one:
Viking 6hp outboard
If yours looks like the one in the pictures on that second link....it's made by Chrysler.....You can post specific questions here on iboats on the Chrysler forum. Lots of great people there.
Good Luck....
They will advise you on the oil/gas ratio.....probably 40 or 50 to one if your engine is a 1965. To be safe....I'd run maybe at 24:1 initially if it's been setting up for a while....
terry schmunk
I believe the ratio is 24/1. I also have a Viking 6hp but its a model 64601. No info!!! I need to replace the impeller and the prop plus minor parts. Mostly the impeller and prop. Can anyone help me with advice?
F_R
Honorary Supreme Mariner
I have the book for a Sea King version of a 1965 6hp, by Chrysler. It is a bushing engine, and most would agree you shouldn't run leaner than 24:1. The book tells all the other lube data, but not that one.
steelespike
West bend was purchased by Chrysler circa: 1965 Fuel ratio as a West Bend in 65 is 16:1
I have a after market service manual that lists West Bend 6/65 and Chrysler 66/67. 65 West bend is model 650
66 Chrysler is 6601,6602,6603Fuel mix is 24:1.
West Bend has upper main roller bearing and roller crank pin.
66 Chrysler has Upper main,and crank pin roller bearing.Both years have roller rods.
Interesting that lube description is 1/2 pt. per gallon for 65 and 66.years. Though Chrysler lists 24:1 separately.
