6hp tune up kit ( please see pic)
phatmanmike
<br />this is my motor. 1973 6hp johnson. i only have spark to cyl # 2. i took off the coils. i am looking at ordering a tune up kit from maxtech(maxrules.com) it says it contains, and i quote"TUNE-UP KIT<br />Contains (2) 580148 breakers<br />(2)580321 condensers " what are these parts... in my pic, i assume the green arrow is the points, but what is the pink arrow... could somebody help explain this, my manual isnt very clear, or atleast i dont read it very well....<br /><br />thanks<br /><br />mike
rwise
Re: 6hp tune up kit ( please see pic)
Mike<br />the pink arrow/s points to the condenser/s, the green to the aaaaa points (breaker/s)
DHPMARINE
mike,Where the lower coil was mounted (in your picture)....<br /> Is that dark area like a black burn mark?It's a little hard to see,but possibly that coil is arcing to ground,causing loss of spark.Looking at the coil should tell.Usually best to replace coils in pairs.(and new wires as well)<br />DHP
phatmanmike
thanks dhp, will do! no, that dark spot is actually a puddle of pb blaster/wd40 i used to remove the flywheel
