6hp Johnson wont start
alexwick007
Hi I have a 1989 Johnson 6hp short shaft outboard motor model# j6rcec. I recently picked up this motor and got around to testing it out this past weekend. It has very low hours and runs very well. It ran all day without a hitch and then right when we got back to the ramp to load on the trailer it would not start. Nothing since that day.
So I got it home and started to do some diagnostics and found it has no spark on both cylinders. I have already unhooked the kill switch and looked around for loose or broken wires and have had no luck. I am kind of stumped at this point and just don't want to throw parts at it. I have no way to test the charge coil or powerpack. It has new plugs, wires, and fuel pump. Just wondering if anyone has had a problem like this and what the fix was. Thanks for the help.
alexwick007
I assumed that's what it was going to be but just wanted to make sure. Just so weird how it worked fine and then didn't. But I gueese that is the fun of electronics! Can you take a powerpack anywhere to have it tested? Like a Auto or Marine shop? Thanks.
moonman
I have a Johnson 8 Hp that I use as a trolling motor. If I run it for 5-6 hrs, it will not start either. The plugs get fouled up and I clean them, then it starts again.
