6hp johnson matience
Smac83
when adding gear oil to lower end, I cracked the screw loose at the bottom, a milky oil came out. I kept pumping new in until it cleared it out. is this normal ? its a cd-25r don't know the year. also is there a prop that would help it push a 1971 14" sea nymph just a little faster. pretty slow. I know its only a 6 hp.
oldboat1
Did you drain out all of the old oil (the milky stuff)? Sometimes the vent or fill screw gaskets can leak -- should replace them with a refill, then run it for a bit and recheck for contamination. If milky again (i.e., water in the oil), will need to find the cause and fix it.
I'm not aware of another prop for it, but could try rearranging weight in the boat -- including yourself (try operating from the middle seat). Do a search for a tiller extension, articulated style.
ondarvr
Check the oil after the first outing, if it's milky change it again, sometimes you need to change it more than once to get all the water out, and use new washers.
​There are a couple of props that will fit, but I have no idea if they list them to fit this motor.
Smac83
thank you both. I will change the gaskets and flush again before I take it out again. the guy I bought the boat from also gave me a 9.9 merc and a 4.0. fuel line bad on the 9.9 and knew nothing on the 4.0. I can turn wrenches on cars but that's a different story. was raised to ask question if not sure. outboards are a new toy in my older age and thank you kindly for the insight. hope to have the 9.9 running soon and change it out. I will try to relocate stuff in the boat and see if that helps. yes every thing is in the rear, battery, trolling motor, gas tank and me. she is kinda nose high when at full throttle. it is an old boat, but my first. only up from here. lol
thanks again. feel very lucky to have found this site. happy boating.
