6hp Evinrude Slow to turn RPM
The Mallard
I just recently purchased a 1989? 6hp SN#B1633852 Model #E6RCCS. The boat ran great on a test run. Got it home, changed lower unit oil with new 80wt. and replaced w/new spark plugs (gapped at .040). The engine to seems to "load up" or "bog" when accelerating. The boat takes 10-15 secs to reach full throttle and seems not to reach the same peak rpm as in the test run before changing plugs and lower unit. Any ideas what is causing the slow throttle response? Thanks for any suggestions. <br />Mike
sloopy
Re: 6hp Evinrude Slow to turn RPM
What type of boat is it pushing? <br /><br />COULD be the carb..... But might be the boat....
JB
Ahoy, Mallard.<br /><br />Your model number indicates a 1988 model.<br /><br />Regap your plugs to .030. What plug are you using?<br /><br />Check that the ignition stator and carb throttle plate (butterfly) both follow the throttle without sticking. <br /><br />Let us know what you find. Good luck. :)
The Mallard
Thanks JB. I will regap the plugs and let you know what type of plug I am using. I will also check the throttle plate and make sure it is not sticking. It might be a day or so before I can get out to test after these changes but I will post results. <br />Thank you<br />Mike
The Mallard
I tried new plugs gapped at .030. and I am using champion plugs QL77JC4. I am still experiencing slow acceleration out of the hole but once the motor gets going the top end is not bad. Any other suggestions to improve the acceleration out of the hole..<br />Thanks Mike
OBJ
Hey Mallard,,,,<br /><br />Just a set up question, where is the anti-cavitation plate in regards to the keel of the boat? What I'm getting at is, you are not using a long shaft engine on a boat that needs a short shaft are ya'?
The Mallard
Outboard Jim, I am going to say that the motor is standard length. The shaft is approx.8-10" below the "bottom" of the boat. The boat is a flat bottom 12'alumnacraft.
OBJ
That's probably yer problem Mallard. To much lower unit hanging in the water. Lots of drag. The Anti-cav plate, that's the plate right over the prop, should be even or more than an inch above or below the keel. That's just a rule of thumb but it works. If ya' can get it up some, may help or shop around for a short drive shaft and shift rod and turn it to a short shaft.
OBJ
I just took a look a yer model number and it don't indicate a long shaft. Is there a 5 inch spacer right above the lower unit. If there is, you will have two mating lines between the lower unit and midsection.
The Mallard
Thank you Outboard Jim. I will have to measure the length below the "bottom" of the boat to be sure. Is there any possibility of something in the carb? <br />Thanks Mike
OBJ
Sure. But if it's good when after coming up, don't seem likely that there is. I mean if something was plugging up the high speed jet, it would all the time and not just coming outta the hole. If you find that the lower unit is OK, get a service manual and check out the cam follower adjustment. Should be a roller riding against a cam under the flywheel just above the carb. The cam has a hash mark on it. When this mark is centered with the cam follower roller, the throttle plate should just start to open. This could make it drag outta the hole if it's outta adjustment.
The Mallard
I will have to look at the motor, it is stored at another location. These mating lines your talking about, if my motor has it, is this an adjustable part to shorten the motor? :confused: <br /><br />Thank you Mike
The Mallard
Thank you for all your suggestions. I will check out the motor in the morning and see what I can find out.<br /><br />Thank you <br />Mike
OBJ
Yeah Mike....but you would need to remove the extension and install a short drive shaft and shift rod. But let's find out first. Keep us posted on what you find. We're here to help.<br /><br />Thanks.
rickdb1boat
Might be able to fabricate or buy a extention, similar to a jackplate, to avoid the costs and hassle of getting a driveshaft, shift shaft and water tube. Even bolting a 2" thick wood one on and mounting it to that should work on a small 6 HP, to make up the 5". Just a thought!<br /><br />Something like this would work perfect and keep your motor intact. $90.00. Probably less than you would pay for the other parts to convert to a short shaft.<br /><br /> web page
OBJ
That's a good ID rick.....Cheap jack plate and yer good to go. :D
