scott_maier
Thread starter- Joined
- Mar 16, 2009
- 124
Motor is driving me batty. I've got fuel coming out the carb after a few pulls and the motor won't idle well or start very easily. I can spray fuel directly into the carb and it will fire up. It's weird because fuel is pouring out the throat of the carb but not going in!
compression: 85 psi on each cylinder, took off head and polished flat, cleaned tops of pistons, new head gasket, checked thermostat and put back with new seal and gasket
ignition: new coils, points, condensers, spark plugs, timing is good i checked it with timing light (when i had the motor idling), the spark will jump a 1/4" gap on both wires.
Carb: Rebuilt carb(twice) with poly float(the 2nd time), I did remove the welch plug covering the idle holes - cleaned and put a new one in.
Fuel pump: I bought a rebuild kit off ebay and installed it. It seems to be working good. I can remove it from the crank case and squeeze the primer bulb and no gas leaks out the hole on the back. It will also fill the carb bowl and pumps when the motor is running.
Gas: I can hook the tank up to my 55hp johnson and the motor will fire right up so i'm thinking the gas isn't bad, it' about 2 months old though.
-New reed valves, I polished the reed plate with sand paper on a granite block and re-installed with new gaskets.
I don't know why the gas keeps pouring out the carb throat after a few pulls. I'm wondering if the rebuilt fuel pump is causing some kind of problem.
I'm at my wits(and monetary) end on this. Any help will be greatly appreciated. Thanks in advance...
