Raven Blayde
Thread starter- Joined
- May 28, 2008
- 9
Hi everyone! I recently bought a 68' Mercury 35hp 350 motor (serial # 2301754) that was only running on one cylinder when I got it. I replaced the points, checked the gap, condensors, and replaced the #2 ignition coil that was cracked. Unfortunantly, the motor still ran on only the #1 cylinder. Tried 3 other sparkplugs, but still no fire coming from #2. Even with a new sparkplug hooked to the sparkplug wire and the motor fired up (with the plug out of the motor), it still won't spark, so it's not flooding out or anything. I'm begining to question the connection between the sparkplug wire and the new ignition coil. The ignition coil has a hole with what appears to be a small pin inside of it. My sparkplug wire had no connector at all on the end and I assumed that the end of the wire simply pressed into the hole of the coil to contact with the pin inside. Was this plug wire suposed to have a connector of some kind that I don't have? If so, I need to know what it is and where to get it. Thanks in advance.
