68 Johnson 33hp lower unit lube question
Tectonator
I've got a quart of Type C lower gear lube leftover from an electric shift Evinrude I used to have. I want to get rid of it...will it work
to use in a 68 Johnson 33hp outboard? People refer to it as "Premium Lube", so maybe it is better than the normal GL-5 stuff? Or is it too thin?
Thanks.
F_R
Honorary Supreme Mariner
Actually, in times past, it was the recommended lube for your motor. So, you are good to go.
