moevinrude
Thread starter- Joined
- Mar 23, 2011
- 22
I just got this 9.5 through some trading.
First, where does the water come out from cooling the engine? I want to check the water pump in a barrel.
Next, Where does the exhaust exit? I see the exhaust port on the back of the motor and under the cowl. Is this the only place it escapes?
How can you tell if the motor mounts are shot? I can move the motor about a half an inch in any direction, but it is not sloppy.
Which motor mounts go out, the ones within the cowl or the ones just above the lower unit?
What are the problems surrounding the motor mounts being bad? Will the motor quit performing?
I can't believe with a bad motor mount that someone cannot just wedge something between the outside case and the motor itself.
Thanks for helping me,,,,,,,,,,,,,,,this forum is awesome and has many good poeple willing to help.
