moevinrude
Thread starter- Joined
- Mar 23, 2011
- 22
1968 sportwin, 9.5 Okay,,,,I have been replacing ignition parts, gas lines, and installed kit in carb. Finally complete,,,,or so I thought.
Took this motor out last wknd, ran like a top for 10 to 15 minutes. Then would only run with choke on. Did find old fuel line garbage in the bowl of the carb. I have taken the carb apart, seriously 12 to 14 times since, and cannot get the low idle side of things to work. Most of the time it works great with the throttle half to full, bowl is clean as a pin.
I have tried cleaning everything with carb cleaner, and have it soaking now. The low idle holes in the throat do spray out some when I blow the cleaner in the hole underneath. I am just not sure what else to do. I even stuck a needle in these holes as far as I could.
What else can you do? The motor sounds great when I have the choke on. The low idle knob does nothing at this point. If I spray gas over the barrel it works good as well. Any suggestions would be great.
Thanks
Desperate
Thanks
Desperate
