68 55hp Evenrude Elec.Shift Problem
Love My Toon
Electric shift starts in forward after it starts it can be changed from foward to reverse with no problem! The problem im having is I have no Neutral? Any awnsers would deeply be appreciated.
OBJ
Re: 68 55hp Evenrude Elec.Shift Problem
Hey Toon....<br /><br />The engine is designed to be in gear until the engine is started....this feature is so that if you lose the power to the shift solenoids for some reason or they go bad, the engine will still be in gear so at least you can get home.<br /><br />Now if you don't have neutral with the engine running, that's a different case. Do you have neutral after the engine is started?<br /><br />Thanks.
Love My Toon
No i dont. When i push the button for netural it goes in Reverse also Forward and Reverse gears will change properly just wont kick into netural
Joe Reeves
You have a Hydro Electric Shift type engine and it sounds like you are using a older style Electramatic Shift type shift switch.<br /><br />Electramatic wires as follows:<br /><br />Forward = 12v applied to green wire.<br />Neutral = No voltage applied.<br />Reverse = 12v applied to blue wire.<br /><br />Hydro Electric wires as follows:<br /><br />Forward = No voltage applied.<br />Neutral = 12v applied to green wire.<br />Reverse = 12v applied to both green and blue wire.<br /><br />The following may be of interest to you.<br /><br />(Hydro Electric Shift)<br />The shifting setup of the lower unit is what's called a "Hydro Electric Shift", which is quite complex consisting of voltage being applied to solenoids in the lower unit which in turn change oil passages via a oil pump that supplies various pressure on a spring loaded shifter dog. The wires leading to the lower unit (at the powerhead) are "Green" and "Blue". The engine must be running or cranking over in order to shift out of forward gear.<br /> <br />You CAN NOT use HI VIS lube in that lower unit. You MUST USE what OMC calls "Preminum Blend" lube, commonly called "Type C". (A thinner lube) <br /><br />In neutral, you need 12v to the "Green" wire. <br />In reverse, you need 12v to both wires, the "Green" one and the "Blue" one. <br />In forward, there should be no voltage to either wire. (The spring loaded shifter dog forces the unit into forward gear) <br /><br />To check the lower unit for proper shifting to make sure you have no trouble there, remove the spark plugs to avoid problems and to allow a higher cranking speed. <br /><br />This next step eliminates the actual shift switch in case problems may exist there.... Disconnect the blue & green wires at the knife connectors (the rubber insulated boots) leading to the lower unit at the powerhead, then using jumpers, take voltage direct from the starter solenoid to apply voltage to the "Green" wire for neutral, then both wires 'Green" & "Blue" for reverse (Remember the engine must be cranking over in order to shift).<br /> <br />With no voltage applied, the unit should be in forward. No need for a ground jumper... the lower unit's already grounded. You may crank the engine with the key switch or by energizing the starter solenoid with a jumper wire.
Love My Toon
Thanks Joe will get back to work on this this week your info is very appreciated.Will reply back to you if that was my solution Thanks again.
