67 mercruiser 120 hp
charliez
After replacing the lower shift cable , bellows, points & plugs along with a probably not needed new coil ,new fuel pump & cleaned fuel lines along with the tank.oh plus new impeller & tilt trim major repairs I am almost ready to try it again I am having a little trouble adjusting the new shift cable seems to go into forward OK & neutral but reverse is not right ,anyone have any tips to accomplish the adjustments?
Re: 67 mercruiser 120 hp
Ayuh,... Bein' a 67,... Did you install the Updated kit,..??
charliez
Yes access to manual, Great link! Going to try this.
No , old style cable installed.
