gmarshall43
- May 5, 2002
- 216
I have a 1967 Mercury, model 110, 9.8hp. The problem is it stays in forward gear. It won't shift into neut. or reverse. I have the lower unit off and I can shift it into forward/neut./reverse with no problem. It mates up with the shift shaft from the top half but I think it maybe stripped causing the shift shaft from the lower unit to not move when I shift from Forward to reverse. I want to take the shaft out of the upper section and look at it but it doesn't look to be easy. Is there a simple process to get it out of there?<br /><br />Thanks
