67 Johnson Seahorse stopped running
miklor73
Ihave a 67 seahorse, model # CD-24D. I was out on the lake yesterday, motoring along, when the motor just kind of wound down to nothing, at wot, and died. Any help would be appreciated. Had a full tank of fuel, getting fuel, just won't run. I can get it started for a minute, but it sounds like its running on one cylinder. I put a spark tester on it, has spark on both cylinders while running.:mad:
miklor73
Re: 67 Johnson Seahorse stopped running
I could really use some help with this.
lindy46
Could be a bad coil - shorting out when it gets hot. You would have spark at idle but not at WOT. Have you tried pumping the bulb when it starts dieing? If pumping keeps it running, look at the fuel pump. More likely the coil, though.
