67- 120hp
charliez
Well, the old boat has been taken out several times & most of the kinks have been worked out.
Having a fuel problem, each time I have taken it out at some point it has experienced starting & cutting out (bogging at all speeds) for a time. At first I discovered no fuel in the clear filter exteriorr) filter so removed the fuel cap & soon fuel was flowing again ,restricted vent?
Not sure, it was cleaned throughly but may have kink that I can'easily see.
Next hard starting after running hour or so. Seems to be flooding after shut off ,had carb rebuilt but its been several yrs. Can these two problem have the same cause? or is separaterate problems. Other than this boat runs as well as it did back in 67...Thanks
