66 rude pissin fuel out bottom end
Ninjafied
ok so ive been tring to get this old 60hp running and i think im pretty close had no spark so i changed the points and condenser now got good spark, made a new wiring harness for engine.
now when i first start to crank the motor it almost starts but then fuel runs out the bottom of the motor while cranking but no longer tring to start.
has anyone else had this problem,know how to fix?
thanks
Daviet
Re: 66 rude pissin fuel out bottom end
Where is the fuel coming from, pump, broken hose, carb?
Ninjafied
fuel was coming out the exhaust port above to prop so i rebuilt my carb it was very dirty pluged ports and junk
also new plugs and wires just waiting on the brass screw ends to come in for wires then will try to start again
freddyray21
bad fuel pump diaphragm pumping raw fuel into the bypass and out the exhaust.
Silvertip
Honorary Supreme Mariner
Float adjustment is wrong or bad needle and seat.
Ninjafied
already rebuilt the carb just waiting on new tips for plug wire then ill try to start motor
nwcove
did you do the "blow through fuel line with the carb, upside down"? sounds like float needle issues to me.
