66 evinrude won't shift
Sozzy1269
Took out the boat for the first time since swapping motors and it would not shift into forward. Thinking shift dog. Would the bottom end from my old 63 Johnson 28 swap onto my new 66 evinrude 40?
Tater72958
I had an 18hp evinrude that wont shift in forward and when it would shift, it wouldnt stay. The shifter level on the side of the motor has an adjustment bolt on it. I loosen it up and adjusted the level. Worked great after that. May not be your problem but worth checking into.
Do you have reverse?
Chris1956
Honorary Supreme Mariner
Those mechanical shift motors (you do have mechanical shift?) had a shift cradle that was soft metal They do wear out, and they were cheap to replace. Maybe that is your issue?
Sozzy1269
It is mechanical shift. I had noticed the shifter on the motor seems sloppy. I'll look into the cradle. Where is the level and how do I adjust it? Thanks
Tater72958
You do have a tiller drive right? The shift level on the right side of the motor?
The adjustment boft is "i think 7/16 socket will fit it. I believe the level it slotted.
Ill try to post a pic
