glassmaster68
Thread starter- Joined
- Feb 17, 2010
- 227
PUMPED THE PRIMER BULB TIGHT AS USUAL,,,STARTED THE MOTOR,,,,DIED LIKE WAS OUT OF GAS,,,,WENT TO PUMP UP BULB AGAIN AND IT WAS TIGHT,,,FELT LIKE IT HAD NO GAS IN THE BULB,ALMOST LIKE IT BACKFLOWED SOME AIR BACK INTO IT.,,,,,TANK VENTED FINE,GOT A NEW PRIMER BULB LINE,,,SAME THING,,,,,,,SUQEEZED THE BULB HARD,TRIED TO START,,,,, AND ENGINE SEEMED LOCKED UP AND WOULD NOT TURN OVER,LIKE A VAPOR LOCK OR SOMETHING,,,,,TURNED OVER A FEW MINS LATER,BUT SAME THING,SEEMS LIKE BULB IS GETTING PRESSURIZED ,,,,,,,,,,,,,JETS ARE CLEAN,FLOAT WORKING RIGHT,,,,DONT KNOW BOUT FUEL PUMP THO,,,COULD A BAD FUEL PUMP CAUSE THIS?
