66 evinrude 6 hp frustrated wont start
jewelldday
My new looking 1966 6hp died a couple weeks ago going half throttle and wont start. Here Are details carb rebuilt fuel getting to cylinders. Compression 90 psi each cylinder. replaced coils and points cleaned armature set point .020. Spark test has big blue spark at 1/4" gap. starting fluid and fuel added to each cylinder. Not even a bang when started. have taken armatur apart multiply times and cleaned everything. new plugs to. Is there anything else I can be missing. When it died it just turned off like grounding the plugs it restarted a few times but would run 15 mintues before it died all togeather
Thanks
Derek
OptsyEagle
Re: 66 evinrude 6 hp frustrated wont start
Is it possible that your either have the spark plug boots OR the coil clips going to the wrong cylinder. If so, you would still be getting good spark on your tester but the spark would be timed at BOTTOM dead center and hence not run.
jewelldday
I'll check but i'm fairly sure i didnt change anything the top wire has the "top" clip on it
Daviet
All it takes to make your engine run is timed spark, compression and spark.
It sounds like the compression is ok.
The spark will jump a 1/4" air gap, is the flywheel key in good shape and is the flywheel torqued to proper spec?
Remove the plugs and make sure the cylinders are not flooded, use a spray bottle with fuel in it, squirt some fuel into the carb, pull the choke and see if it will fire off.
nwcove
would run 15 mins before it died after the original issue? id go back to the carb, and check the thick washer on the hs jet. i had the same issue with a 3hp, but it would run with fuel being sprayed into the carb. the motor was a no go until i put the old thicker washer back in the carb.
