65HP '72 Evinrude cooling water routes
BBLUNT
I've read previous postings and still am left with a bit of confusion. 1} with motor running is it normal to have a stream of water coming from the small notch in front of the L/U housing? or is it a sign of needing to put in new grommets and gaskets.2)When the thermostat is closed the water is routed where? 3)If water is coming out the two 3/8" dia. openings( pressure relief?) in back below the cowling this means what? <br />I don't mean to beat this to the ground just trying to learn what I should be expecting when I run my motor. I appreciate the info, thanks in advance.
Kiwi
Re: 65HP '72 Evinrude cooling water routes
Hey BBLUNT, I owned one of these engines some years back and in my opionion ....<br />1. Yes thats normal, mine did that as well when out of the water on muffs. From memory there was another drain hole somewhere on the side of the L/U that also did the same.<br />2. As I understand it, when the thermostat is closed the water only circulates around the power head until it reaches correct operating temperature at which time the thermostat opens and cool water is allowed to enter the cooling system. After the water has been through the powerhead its dumped into the exhaust system and either shot out the prop hub or via water relief outlets.<br />3. On the Evinrude 65hp engine I owned very little water ever came out the Relief outlets. At idle there was usually nothing and at full throttle there was only a very small flow which snaked its way down the leg. In comparision my brother in laws Evinrude 135 had what I would call a full flow from those outlets at full throttle, but bigger engine, more cooling and more water to expel, I guess.<br /><br />You have a good engine there :) If the water pump impeller hasn't been changed in the past couple of years I would do that just to be sure that you are getting full water flow through the system. The engine I had didn't have a tell-tale, although there was a overheat warning buzzer which fortunately I never got to hear !<br /><br />Cheers, hope this helps.<br /><br />Mike
BBLUNT
Thanks for the info. I'm in the process of installing a new impeller. The only other problem i have is the tach is not working, it appears to be wired up okay it shares its ground with an hour meter and i'm thinking the hour meter may be bad cause continuity is showing across the ground of the tach and the hot side of the hour meter any suggestions here? Again thanks
Kiwi
Your tach problem might be one for Schematic ! :confused:
RHiner
I have been searching the forum to solve a heating problem with a Vintage 65 Evinrude I recently acquired. I have changed the impeller and checked and re-checked the installation for correctness. (tubes aligned etc.) I am convinced that I have a thermostat problem but alas - where is the thermostat located now that I know it has one. This motor may have not been run in over 10 years - but with new plugs and clean carburators it runs - just tooooo hot! Help!! How do I get to that thermostat?
papasage
i have a 74 70 hp it is at the top of the head mr 79 is behind the plate that in on the outside of the head on the bottim of the head . i think my 72 is like the79 . i just replaced the stat and waterpump on the 74 . it dont have water coming out the back till you pull the warmup leaver half way upthin it comes out good . it runs a little warm at idle . i can bareley hold my finger on the head to a 5 count . it never gits hitter than that cools down when rpm are raised and water will flow . going to change the plate under the waterpump . if that dont work i will run itlike it is .papasage
