'65 9.5 hp Rood drive shaft stuck
oldphart120
Any body have any tips or tricks to remove a stuck drive shaft? I removed the gear case and the drive shaft stayed in the l.u.. Needless to say the pump housing was damaged by the pin that drives the impeller. I 'm pretty sure I can fix that. The problem is pulling the shaft out of the crank. It seems to be stuck pretty tight.
oldboat1
stuck driveshaft (powerhead)? -- probably will get an assortment of ideas on that.
Might tip the powerhead upside down, and run some ATF down the driveshaft toward the powerhead (try to get some into the splines) -- a little soaking with that.
For gripping the shaft, a piece of rubber mat or heavy gasket material, and a sturdy vise grip. Mount the motor on a stand or sawhorse, and get hold of the driveshaft with the vise grip (keeping away from the splines on the gearcase end.) Smack the vise grip downward with a hammer, using appropriate language for the trouble caused.
F_R
Honorary Supreme Mariner
And if it doesn't come with that, you have major problems. Removing the powerhead is an intimidating job for most people. Option #2: Put it back together the same way you took it apart. File a notch in the pump housing for the pin to pass through. It will last until the crankshaft splines are totally rusted out and won't drive any more. Maybe a week, maybe couple of years.
I fabricate adapters to clamp on the driveshaft and use a slide hammer.---But as said there may be rust damage to the crankshaft splines and that could be a deal breaker.
Crosbyman
after the ATF oil soaking for a few days try tapping the shaft into the power head before trying to pull it out a slight movement will allow the oil to penetrate a bit more... soak again for a few days
then try pulling it out with but firm taps
why not peek inside with a fiber optic cable to see how bad things are ...kind of a colonoscopy :)
oldphart120
Thanks for the tips.
The power head is doing a headstand today to get a soaking with Ed's Red penetrant. Ed's Red contains ATF. Good stuff cheap. Google it. I'll make a gripper block to grab the shaft and pry against a tube slid over the shaft bearing against the crank end. This will eliminate putting pressure on the crank bearing webs. I already tried the vise grip. The shaft is hard and the pliers slipped quite readily.
oldphart120
Thanks for your comments.
Not many machines intimidate me. :) Some wimmen do. :lol:
The notch is in the pump housing already. Made by the pin when I slid the gear case off and the shaft stayed in the power head. There doesn't seem to be a seal between the pump housing and the shaft. Water is allowed to travel up the tube the shaft is in and soak the upper end. Is there a seal at the top of the shaft to keep water out of the splines?
oldphart120
Thanks for the tip.
The gripper block will be done in a day or two. I've got a pretty complete small machine shop here. I used to be a gunsmith. Lathe, horizontal and vertical mills, surface grinder etc. A bit of rosen on the bore of the gripper block makes it work even better. How hard can I wack it with a slide hammer before I damage the bearing webs in the crankcase?
oldphart120
I lent my fiber optic device to my proctologist a while back. He wouldn't give it back and I don't want it back.:eek: I'll take a peak with a flashlight though.
My fishing buddy told me to hit it with an impact to move the shaft to loosen it up. But that's in the wrong direction. It might just get tighter.
oldphart120
I appreciate the responses from everyone to help with my dilemma. (sp?) I'll post results and observations later when I either fix it or part it out.
hardwater fisherman
You asked if there was a seal on the shaft to keep water out of the splines. There is an Oring that fits in a groove on the driveshaft just below the splines. Part number 0303067.
