I have a very good condition fisherman that has started accelerating and decelrating on its own as you run across the water. Everything else is good. Any thoughts
Is change in power level sudden ?------If yes than you may have spark issues.----If coils are original; you may need a set of new ones.-----Have done complete overhauls on more than 6 of these motors in the last couple of winters.-------All had new coils already and 2 motors needed a set.---Simple to check that out.
Appreciate the responses. New fuel supply lines and bulb. Not a sudden "jerk" gradual increase and then decrease. I noticed that if I put pressure on the carb throttle linkage on the top of the carburetor, it will even out.
