64' Rude Port Bank heating problem
RT290
I have an 1964 (or 63') Evinrude v4 Model #75393E.. the reason I list both years is because the manual I have for this engine doesn't show my specific model number.. the series ends between 63' and 64'. My question: The port bank of cylinders (back of boat facing forward) is getting a lot hotter the the Starboard side. The "hot" engine light is working, as I grounded out the lead and the dash light came on.. However, the "hot" engine sending unit is located in the STBD bank, the "cooler" of the two.After about 4-6 minutes of running the engine, the Port side begins to become too hot to touch, while the STBD side is relatively cool...I've pulled the port head and cleaned the water jacket, no corrosion at all.I would hate to have to pull the exhaust manifold as it would mean taking apart the whole top end(fly wheel,distributor,ect)to inspect . It seems that the supply of water for cooling is OK, but the port bank does not seem to be circulating fast enough.Are there any Water Treatment Chemicals someone could run through a cooling system that might break down and eliminate build up? Any Suggestions? <br /><br />Thanks in Advance, <br /><br />Rich from Oregon
Terry H
Re: 64' Rude Port Bank heating problem
The port side running hotter seems to be normal...on mine I was concerned until I found that it cooled down ok when I got the rpms up...don't know why, but an old Evinrude mechanic said this was normal with those old v4's...if you find a solution I would like to know also...just a Thought
