'64 Edinboro Custom
ngfarr08
Hello All-
So i recently came into possession of a '64 Edinboro Custom, it needs alot of work, but before i really dig in i had a few questions about the general construction of the boat. I know my first real step in resurrecting this boat will be replacing the transom. I was also thinking of replacing the floor, having spent a bit of time around a MFG Carefree i know that there is a wood sub floor in those boats between the hull and the inner glass floor. I know that the Edinboro is constructed using a sub floor sitting on top of stringers so before i dig into the floor i was wondering if someone could clarify a few things about the construction of the floor on the Edinboro, my first thought was that it was marine ply sitting on the stringers covered with glass, but as i probed a bit into a few pre drilled holes if didn't feel like there was any wood in there, also having read a few posts about '64 Niagaras and a few Edinboros it seems to me like the floor may be just solid fiberglass, could this be the case? also i was curious to see what the stringers are made of, i know on the Niagara the stringers are straight glass, so i was curious if this was the case on a Edinboro as well?
Jon Sob
Master Chief Petty Officer
Re: '64 Edinboro Custom
Hi ngfarr08 ...... Welcome to iboats. I am not the one to answer your questions but I am sure someone will be along that can. When I bought my MFG there was no sole in it so I have no clue what is in yours and it also doesn't help that I am new to boating. I can tell you that my stringers are made of aluminum. If you don't find your answers here you might try posting on the restoration section .... you might find help there as well. Good luck with your project.
*EdC*
Hello All-
Welcome aboard!
My '68 Edinboro has glass stringers and a glass floor. I'll bet yours does too. Check out this link for more info. http://www.fiberglassics.com/library/File:Mfgb64003.jpg
sphelps
Hello and welcome aboard Ngfarr! It seems you have the the same boat as I do. Does the deck feel weak or soft ? There should not be any wood in the deck or stringers only in the transom . I hope you can post some pics soon! I,m interested in seeing what she looks like...Maybe she's got one of these?
See ya ! S.P.
