`64 9.5 sportwin lower unit hole?
r0moneyb
Hello all,
I was getting ready to put my motor back on the boat and I noticed a small hole on the lower unit.
The outside edge of the hole looks rough. But, the inside edges of the are very smooth, almost as if it was drilled.
Does anyone know if this hole is suppose to be there or not?
If it needs to be fixed, would a small dab of JB weld do the trick?
Thanks all, Ryan M.
kbait
That hole drains your exhaust housing when motor is pulled from the water.
Honorary Supreme Mariner
It should not be plugged.----Look for another hole near the front and make sure it is clear also.---They need to drain water to prevent freeze cracks in cold climates.
