Pleasetow2ramp
Thread starter- Joined
- Jul 30, 2018
- 9
I got a 14 foot fiberglass 63 P 14 that came with the 1963 super seahorse. It’s been quite the project. At first was knocking really bad and slipping out of gear. I did a lot of lurking on the forums and figured out it was the clutch Dog. replaced that and it seemed to be working great but somehow I messed up the pivot pin. I think it missed the hole... it worked fine for two trips and after that had a catastrophic failure out on the lake. Seems that the cradle came out of the shift Rod assembly. I fixed it. Resealed the lower unit new impeller resealed it made sure that the shift rod pivot pin is in the right place. I think the lower is squared for now....
The engine will start and run reliably but will not idle. I have ran a can of seafoam through it. It didn’t seem to change anything. I do see the glass fuel filter with the nylon inside of it is full of gunk do you think that could causing it to idle rough? The carb looks really hard to take apart all the way? Is that it? When I start it you have to give it gas in it will run fine and will scoot around the lake just fine. At low speeds and I can get it down to cruising at around 2 miles an hour but it starts to run really rough at lower RPMs and will die and not idle . any ideas?
