trebot
Thread starter- Joined
- Jul 7, 2004
- 102
New motor to me. Rebuilt carb (what should float level be ? ). Rebuilt fuel pump ( diaphram & check valves ). Runs rich to point of raw gas/oil discharge from exhaust. Compression 90 on both cyl.. Tried bypass fuel pump. No change. Does have very small leak at reed cage housing gasket lower port side. Could this be causing problem? Don't understand purpose of reed cage. Motor starts easily, idles Ok, SMOKES at high idle and up. Plugs wet. Thanks, Kurt
