63 5.5 gear housing seal stuck
cincyparrothead
I've run into an issue removing the oil seal on the drive shaft housing assembly. I was trying to lunch it out from the back and all it managed to do is destroy the seal. The o ring and spring came out but the rest of the seal is stuck. Any suggestions getting it out? Looks like a replacement part would cost $120 so I would like to avoid that if possible.
F_R
Honorary Supreme Mariner
You are wise to be cautious. It is easy to bend or break that thin bearing housing. If you are fortunate enough to have a Dremel tool, grind a groove almost through the side of the seal shell, till it is paper thin. Then it should be easy to pop out. For myself, I chuck it up in my metal lathe and cut it out. But it is rather unlikely you have a lathe.
Other option is grab the thick part of the housing in a vise and lever the seal out with a big screwdriver or similar tool.
cincyparrothead
I thought about using the dremel but wanted to ask here first. I found a used housing on eBay with the seal already removed and bought it so now I can be a little more adventurous on the removal.
HighTrim
Gently mount it in a vice, and when your pry the shell out, use a seal puller tool. Do not leverage against the shell, it is thin as stated and will break if too much pressure is put on it.
