62 merc 2 outdrive help
riverqueen
I have a 1962 river queen with the original motor and outdrive,trying to restore.Last season the outdrive locked up.I know the parts are hard to come by however the last owner gave me his book with tons of part contacts across the country.I live in the upper Midwest and looking for dealers to rebuild outdrive as I am not mech. inclined.Any help in locating a seasoned mechanic qualified for these older units would be appreciated.I belive this is the first model merc. produced.model 2 sn. 1534238 powerd by grays marine 327.VERY FUN BOAT!!!!
Re: 62 merc 2 outdrive help
Ayuh,.... Welcome Aboard,..... I'm thinkin' findin' a qualified Mechanic is gonna be as tough as findin' parts for that driveline,....
1990's hulls are now rottin' out,....
A 1990's driveline would be a Great up-grade to yer hull,....
Phreaq
Bondo is right (per usual) time to find a new used outdrive/boat.
I have been told many times that the motor would also have to be replaced with the outdrive, due to bolt patterns and input/output shafts. I haven't looked into it yet. However I know Advance Adapters has been making t-case and transmission adaptor plates for a long time. I bet they could make an adapter for boats ... but it might take a petition or pre order list to get them to do it.
I don't recall the input/output shaft makers. Those often come with kits (i.e. Slip Yoke Eliminator kit for 4wd), but I think I had come across a vendor when I was looking for info on swapping 4wd XJ parts into a 2wd XJ. If I can find it, I will post it here for you.
But when that time comes for me, that's what I will be looking into. As well as searching for an existing adapters.
When it's all said and done, this may be a more expensive route, and still does not address your mechanic situation. I live to far away to help you with that.
I would love to see some pictures, and more information about your boat. I have a 1965 Silverline that I am having trouble identifying my mc(?) parts.
Post a new thread for it (please), not trying to hijack this one.
