61' johnson 75hp (seized crank) is she worth keeping?
R.Johnson
Re: 61' johnson 75hp (seized crank) is she worth keeping?
Unless it is something you simply must have, no! This would be a real money pit.I have bought these motor's running for $25.00, and turned down others for free.
rolmops
Hello.<br />These are big time fuel consumers that make fantastic anchors.<br />In my opinion you can do better by spending your time and money on a more fuel efficient and lighter '70s or 80's model.<br />However, if you like puttering around and fixing things because you enjoy doing exactly that.You should by all means go ahead and fix it.<br />I fear that I might be inclined to do exactly that.<br />good luck.
JB
Hi, Starz.<br /><br />I agree with the posts above. Too big, too old, too heavy and too thirsty.<br /><br />If you tear it down you may be able to get enough for the good parts on Ebay to find a decent 2 or 3 cylinder looper JohnnyRude that is everything the old horse isn't.<br /><br />Good luck. :)
