captjeff
Thread starter- Joined
- Mar 21, 2010
- 6
Hi guys,
I have a 61 johnny 18 hp. last year it ran well, started after 2 or 3 pulls and ran. This year I can't get it to run more than a couple of minutes. It will start right away after I prime using the bulb, run for a few seconds, sometimes more, sometimes less. Then it will die after "bucking" a couple of times. I cleaned the card and adjusted the float (best I could). I have also changed the fuel line from the tank to the carb, and changed the pump. I added an inline filter and removed it, no change. I've tried re-adjusting the carb needles, no change. I had put in new plugs at the begining of the season, but i noticed they foul up with carbon Very quickly. Black ash means running rich right? Then again since it has ran a lot with the choke so i would expect it to be rich. I also checked the reeds, they are in good shape. For a long time I was thinking it was a fuel delivery problem since it seemed to run better if I pumped the bulb while running, but I also noticed it will stall even if the bulb is stiff. I am completely lost... HELP!
