61 75hp from long to short shaft?
utah lakes
I have an Evinrude1961 75 hp 50525, this is the long reach motor. I am trying to convert to the short reach (50524) without the extension. Water tubes, drive shaft and shift rod are all too long. I also have a 1963 Johnson V4S 15R also 75HP this is a short shaft version basically same i picked up for parts. What I am hoping is that I can remove the shift rod, drive shaft and water tubes from it and install on the Evinrude. The Johnson is almost completely torn apart so that removing those few items should not be difficult although I have never done anything other than a new impeller and cleaned the carbs. Is this going to work. I could cut the water tubes to length but if I do that there is no going back,and switch the drive shaft..Awfully risky.... Removing the water tubes is not going to be easy but it does give me the option of reversing course......
F_R
Honorary Supreme Mariner
No Title
Removing the water tubes is a big job. This tool is worth it's weight in gold for getting up in there and cutting them without removal. I'm not sure, but the tool might not be made anymore.
BTW, water tube extensions are available for going from short to long.
