60hp runs bad cold
mrwrench
i have a 60 hp mercury 1988? s/n ob399464 , the trouble is when cold it feels like it runs on 2 cyl, i will pt in to drive and it will boug out and die, i restart it and run at high idle for 10 min you can hear the cyl come back from time to time and then it will come back and run good ,with good power ,as long as it is warm, when cold it will take 10 15 min of high idle to get all cyl, any help ,,carl
jebeebe
Re: 60hp runs bad cold
I would do a compression check. I'll bet the top cyl is lacking. If it is well below the other three, you may have problems. The top one is usually the one to go first.
