Updated june 30: Power pack replaced problem continues
Modle number: E6OELCD 60 horse '80's Evinrude 3 cyl outboard
I was getting the boat ready for the season. So, I started the motor in the yard and ran it for 10 minutes. It started first crank and ran fine after the winter.
I proceeded to take it out to the ocean to see if there were any bugs. After 30 minutes of cruising around the harbor full throttle the motor shut off like I turned the key off. No sputters just off. My friend an I were dead in the water so we check for spark checked the fuel filter and it all checked out. After about a hour of floating we got it to run again like it was before. It started with the help of carb cleaner.
After it started it ran fine so we decided to go WOT again with it. It died about a minute after running full throttle. But started back up this time and brought us in.
I thought I found a fix (it happened to be a non issue) and a day later I brought the boat out again. This time after about 10-20 minutes of cruising full throttle it completely died. We snagged an empty mooring and after draining the battery trying for two hours to get it going again it started up and ran like normal as we putted back to the boat ramp. It only started after turning the motor over slowly by hand 100 or so times. As I was turning it over by hand I noticed one of the cyls does not have the compression that the others do. IDK if that has anything to do with it or not.
Any input would be appreciated.
