60hp merc no spark
Dkeith
I have a 2002 60hp merc with no spark. I was trying to fog engine (running) when the starter engaged at the same rime. I immediately shut down and then tryed to restart but no go. I traced the problem o 30 amp fuse. replaced fuse, tryed to start but it only turned over, no start. I traced the blown fuse problem to the grnd wire in the throttle control box, which had burnt thru to come in contact with another live wire. I repaired grnd wire within control box, motor turns over but i still have no sprark at plugs. Anybody know where I might go from here to correct problem.
andy6374
Re: 60hp merc no spark
Disconnect the wiring harness at the engine, jump the starting solenoid and see if you get spark.
Laddies
Banned
If the grd wire you are talking about was a black/yellow wire the it may have burned the switch box up
