60hp Johnson
jsrps
It will crank over but will not fire up. Sometimes it will crank up and run but once it is turned off it does not always crank right up. it just keep cranking over without firing up. what is the problem?
sandspike
Re: 60hp Johnson
ypu might want to see if you have a good spark. i had a simaler ploblem with my 73 65hp evinrude. it turned out to be the choke not working right. but i am no mechanic , just a thought.
Strauser24
Re: 60hp Johnson
sounds a little like your primer bulb to your engine is not staying primed.<br /><br />Remember to give the year model #, that always helps too.
