60hp 3cyl starting problem
hodgify
I have a 1985 60hp 3cyl evinrude red plug that was rebuilt . Motor starts up and runs good can leave it running on muffs when I shut it of and try to restart it does nothing not even a click , after a couple minutes I can turn the key and its starts right up . I have put in a new ignition switch and a new solenoid and still have the same problem . Have tried adding ground wires but no help , all the wires seam ok . Could it be the power pack is bad or something else ?
Fed
The only thing between the keyswitch and the solenoid is the neutral lockout switch, you might want to try giving the throttle a wiggle.
boobie
Are all your battery cable connections clean and tight ??
hodgify
all cables clean . I can start it and turn it off 4 or 5 times in a row and then nothing . I can start it and not touch throttle run 10 minutes shut it off and it will not start not even click , wait 10 minutes and it will starts . Does the power pack have anything to do with starting ?
hodgify
could the neutral lock out switch go bad ? and can i bridge the switch to test ,
Fed
http://continuouswave.com/whaler/reference/electricStart.html
Scroll down to the drawing & chart at the bottom.
With voltmeter in hand you need to find out why the solenoid isn't activating, it will be difficult if this thing fixes itself after a couple of minutes though.
My approach after jiggling the throttle would be to physically inspect/clean every single connection point starting with the easy to get to ones first.
Note: The red plug is not shown in the circuit but it's there & needs to be checked, it sits after the fuse.
emdsapmgr
Do a test. Bypass the starter solenoid. Jump the starter direct with a set of automotive jumper cables-direct from a known strong battery. If the starter always cranks each time it's jumped, likely the starter is ok. Then it's possibly a bad start solenoid.
hodgify
Hey Fed thanks for the web address , it gives me a few other ideas to test , will try tonight . Also had a mechanic tell me it could be the power pack that it could be getting hot after running and then it blocks the signal to the starter soleniod until it cools down .
Honorary Supreme Mariner
It was clearly stated that the powerpack has nothing to do with the motor cranking over.---You need to accept that as a fact.
hodgify
Thanks racerone I do get that , its been raining to much to work on ,hopefully tonight and I will try the neutral switch and check for good grounds .
hodgify
thanks for the help , I think I got it fixed , will know this weekend when I take her out . Turns out it was the solenoid , did the test with another battery and jumper cables and it started even when the key would not work . Turns out its better to buy new parts then to scavenge through the junk pile for parts.
