60ESL70D no spark
earlg11
Started then shut off now after testing I find no power coming from amplifier assembly. Found new Amplifiers but they are a little to pricey. Any ideas where I could find a used one?
F_R
Honorary Supreme Mariner
Whoa, how do you know you have no power from the amplifier? And even if you don't, how do you know the amplifier is at fault?
boobie
Better get a factory service manual and do some good old trouble shooting.
Amplifier? (rectifier?) I believe there is a thread on iboats regarding how to test the rectifier. Did it stall when shifting into gear, make sure not in gear. Assuming battery connections clean and tight, check/clean ground cable to engine. Sometimes if the starter loses its main ground it will seek ground through the secondary grounds which are smaller gauge wires. One on rear of case, one on top by rubber grommet by bus bar. There is a fuse in the rubber holder by choke cable.
F_R
Good advice, except the service manual is outdated. It tells how to test the system using the neon tester, which is obsolete. On the other hand, the manual does explain how it works, which is the first step in diagnosing.
F_R
Rectifier has nothing to do with the amplifier working or not working---except if the battery is discharged. The rectifier recharges the battery.
And yep, a blown fuse will prevent power from getting to the amplifier, as will cable connections, etc
