I acquired this 1971 evinrude 60173C motor that has been setting for 8 years. I am getting no movement in the attempt to remove lower unit in order to replace water pump. The propeller shaft turns so far then stops.Does this mean it is in gear? If the drive shaft is stuck to the power head how do I go about getting it loosened up?
