longshanks
- Jun 12, 2006
- 188
Mercury 1998 2-stroke 60HP three cylinder, called the '45 Jet'. It came from the factory with a jet shoe instead of a prop. I bought the motor 2 years ago, and prior to my getting it, it sat unused for 3 years. Carbs were badly varnished, and I had them re-built and cleaned by a local mechanic. The motor has since been quite dependable for me.
One thing about the motor has always kind of puzzled me. When powering up the throttle from idle to WoT, it is definitely not a smooth transition. Particularly in the last 1/4 of throttle twist, there seems to be something funky going on. If I twist and hold the throttle at WoT, RPMs seem to 'stick' at 3/4 throttle for about 3 seconds, then surge sharply to WoT setting. Otherwise, the motor runs great, idles well, and uses little gas. When getting out of the hole however, it would be helpful to give the motor a steady shot of WoT, as the boat is not over-powered.
Any ideas what this might be? I know that OB jets seem to accelerate slightly differently than props, but I am thinking that there might still be some crud in one of my carbs. If so, how tough a job is it to take them off and clean them? I have a shop manual, and some mechanical ability.
thanks guys
Shane
thanks guys
Shane
