60 HP Mercury 4 stroke cuts off when warms up.
LarryA657
My 60 Mercury 4 stroke cranks and runs fine until it warms up (about 3 miles). Then it bogs down and will only idle.
alldodge
Thanks
Looks like your motor uses a vapor separation tank VST
Not real familiar with your motor but find the VST and look for a schrader valve (bicycle tire fitting) which will have a plastic cap on it.
Find/rent a fuel pressure gauge and attach to it. Then run the motor and watch the pressure to see if it falls off. I'm guessing the pressure is dropping off or the VST is not staying full
Your motor has a TFI system which feeds the injectors. The fitting might be on it
The ECM will have a connector next to it, which a scanner can be attached to see if there are any codes
Are you hearing any beeps?
