joefixit130
Thread starter- Joined
- May 12, 2010
- 2
Good Day all, I am new to this forum and have seen lots of good info here, Looking for a little help. I'm trying to help my Father with his 60 Hp Evinrude. I am unable to determine the year as the model # is gone. I see where it was but cannot read it. I did however see a stamped # on the freeze or sand cast plug on the head. Can anyone help me determine the year or what do you suggest at this point ... any help would be appreciated. The # is G3778046. The problem we are having is that the engine bogs real bad.. no power off idle thru wot. no change when fuel bulb squeezed, I have gone thru fuel system, cleaned tank, new 50:1 fuel,new fuel filter, tightened fuel hoses-multiple, new pimer bulb, overhauled carbs, new Ngk plugs, the engine starts fine and sounds real good at idle, no cylinder mis-fires,cold or hot. But when accelerated it just looses power and bogs down, but when choke button pushed during this event engine speed increases momentarily like its lean ? I have checked fuel flow from pump outlet line just cranking eng. with spark disconnected, and appears to have good/ ample fuel delivery ... almost feels like a timing issue ??? Please help the fishings getting real good and we are kinda stuck.... any ideas? Thanks Joe
