6 way fuel valve
mcr
Not sure if this is the correct forum or not.
What is the cheapest way to connect and valve 2 permanent fuel tanks to a single 300 mag mpi?
Chris1956
Re: 6 way fuel valve
Either connect the two tanks with a Y connector and add a shut off on each tank, or install a Y slelector valve. Get brass fittings for safety.
mcr
each tank will have 2 lines to the valve.
One for the main feed and one for the return line. I need to be able to isolate each tank. Do I need a 6 way valve?
tommays
Why do you need a return ?
As my understanding is that merc and volvo do not use returns
