I have a 2012 Tohatsu Long Shaft Sailboat motor that has a severe binding issue. You can't pull the start cord with the spark plug out and lower unit removed. I can turn it with a wrench on top with difficulty. Thus, I removed the power head, then cylinder head. Cylinder head and piston bore looked fine. Removed the 2 nuts holding the crankcase head (part # 47 on the cylinder and oil pan diagram) and this is where the binding is occurring. I can easily turn the driveshaft while the crankcase head is moving, but very hard to turn if I hold the crankcase head and turn the driveshaft. Trying to remove the crankcase head but it does not want to come up on the driveshaft. I could cut it off and buy a new one, but thought someone might have experience with this already and inform me on what to do???? No history on the motor, just trying to resurrect it
