6 hp really strange problem
laki101
i have a 6hp 69 johnson that could not get more than half the rpm it should normally have
i found out that it wasn't siled on the plate between the carb and the rest of the motor. i fixed that and on the first test it got just amazing rpm, throttle response in neutral
then i shifted it into drive it would not get any rpm and was running on 1/4 of the power
i shifted it back in neutral and it ran good again
one more thing is that when i turn it off and want to start again is that the carb is half empty so could that be it but how does it run in nutral then ?
any ideas great :)
Daviet
Re: 6 hp really strange problem
By the sounds of it you might be running on one cylinder. Take compression and spark test and see what you get.
F_R
Honorary Supreme Mariner
The same age-old story heard every day. Yep, it is running on one cylinder.
