6 hp mid 70 evinrude
rjhans3
I just got a 6 hp evinrude. Did the thing at the dealer, yep worked fine. Well I've got a strange problem, with every thing together, when I crank it all the way up, it perks up and then basically dies down to a so idle. Lots of smoke (unburnt fuel I'll guess). It a few it goes back to full throttle and then dies down again. Here is the good part, If I pull the cowling off it runs like a champ, if I hold the front of the cowling up 3/4" it purrs like a kitten, if I prop the back up it goes back to the cycle again, Anyone have a clue
Thanks
Honorary Supreme Mariner
Is this in a barrel ??-----------Have tried a fan to blow the exhaust away ?
redneck joe
Not familiar specifically with the 6 hp but sounds like airflow issue. Where does the air come in when the ocver is on?
rjhans3
besides the gaps around all the knobs, there is a 1/4" (there abouts) hole right below the carb. I've removed the gasket material to open it up some but that didn't make any difference
F_R
You didn't answer the question--is it running in a barrel or tank? Yes or no. If you are, that is the problem. It is breathing its own exhaust coming up out of the barrel. Get it out of that barrel and on a boat on the lake. That is where it was designed to run.
ondarvr
It can also be an exhaust leak, with the cowl on it will suck exhaust and run poorly.
oldboat1
I think a lot of guys find a way to clamp a small motor on the side of a barrel. Try mounting the motor on a sawhorse or stand, with the leg in a barrel -- just the leg, not the clamp and leg. Build a sawhorse or motor stand high and wide enough so the top edge of a decent sized barrel fits up just under the clamp. Keep the water level about half way up the leg (probably up near the top of the barrel, with the above setup).
The carb sits higher and further forward that way, not over the barrel. I never seem to have an airflow problem, and that might be the reason.
Not as good as running in the lake, but good enough for basic testing and prepping IMO.
[Not like this: https://www.youtube.com/watch?v=RZb8...&nohtml5=False ]
[More like this: https://www.youtube.com/watch?v=1qIj...&nohtml5=False ]
Chinewalker
Also, check the plug wires to make sure they're not being pushed into the cowling latch when you pop the cowling on. They may be shorting out with the cowling in place, dropping one cylinder, reducing power output.
