No adjustment, friction was provided by a toothed nylon arm that pivots on a screw in top of cylinder block, and a spring shoves it in contact with the armature plate, going zzzt-zzzt as you move the throttle lever. Are the parts all there? If they are, the teeth probably are worn off the nylon arm . ...OR...if somebody has replaced the magneto coils, they may not have adjusted the air gap and they are rubbing on the flywheel magnets.
