cary00silve
- Jan 21, 2007
- 72
I just bought a 1955 5hp gale outboard and took it out today for a test run. At first it was running poorly and not revving out which I attributed to a fouled plug and possibly rich mixture. I leaned out the mixture and it ran great for about 2 minutes and then it shut off. I primed the carb by turning the control knob full left. The motor then started up, ran for 2 minutes and quit again. It kept doing this, which makes me believe the carb is running the float bowl dry and is running out of gas. I pulled the fuel line off and opened the tank valve and fuel flows fine. The fuel is definitely getting to the bottom of the float bowl. I have no clue what to check next because I am new to these carburetors. If you have any ideas I would greatly appreciate them. The motor is a 5hp buccaneer model 5D11B.
