I've just gone through my '59 5 1/2 after sitting for about 14 years.<br /><br />New impeller, powerhead gasket, head gasket, thermostat, points, condenser, plugs (gap set to .020"), plug wires, carb rebuild, and complete fuel tank overhaul.<br /><br />I got it startedand it revved great but it will eventually lower it's rpm and not idle unless both high speed and low speed needles are fully seated (turned in all the way). And in that case, the throttle needs to be wide open for the engine to run at about 1,000 rpm. <br /><br />Float level was checked and set and overall the carb looks in perfect shape. And engine is developing pressure to keep the original tank pressurized.<br /><br />Any help would be greatly appreciated. Have sentimental value attached to this old girl. <br /><br />thank, <br /><br />RPG
